ZEsarUX-7.0
chernandezba
consola_favorita: NeoGeo
Gracias dadas: 10 veces
Gracias recibidas: 72 veces
ZEsarUX-7.0
Mensajepor chernandezba » 26 May 2018, 01:10
Hola!
He subido una nueva versión estable de ZEsarUX :)
Se trata de ZEsarUX 7.0
Hay un montón de nuevas características, muchas más que nunca!
Puedes descargar el código fuente, así como versiones compiladas para Linux, Mac, Windows y Raspberry desde:
La lista de cambios es:
Version 7.0. 25 May 2018 - Xeno edition
Added ZX-Evolution BaseConf emulation
Added BetaDisk and TR-DOS emulation
Added Spectrum +3 emulation
Added Spectrum keyboard ghosting error feature
Added ZX Spectrum Recreated keyboard support
Added improved Spectrum 16/48/+ colour palette
Added a fast spectrum core (with some features disabled) just for slow devices, like Raspberry Pi 1/Zero. Now ZEsarUX is playable on RPi1/Zero again!
Added setting to write protect IDE, MMC, ZX-Uno Flash
Added setting to show changelog when updating emulator version
Added actions to file utilities menu: Copy, Move, Rename
Added setting to disable persistent writes on IDE and MMC
Added setting to add a watermark on the display
Added setting to reduce display to a factor of 0.75. Used on RunZX event
Added setting to save spectrum screen to pbm file (black&white)
Added a setting to dump ram contents to file when exiting ZEsarUX, ideal to run automatic tests
Added setting to exit emulator after a number of seconds (--exit-after)
Added experimental simulation of the SAA1099 audio chip from the Sam Coupe
Added second Easter Egg ;)
Added third Easter Egg ;)
Improved debugging:
* new enhanced debug cpu menu: view TV electron position on screen, new default view, cursor, toggle breakpoints, run to cursor, change registers, and a lot more...
* added cpu-step-over function on debug menu (was already available from ZRCP)
* added function to write byte to file on ZEsarUX hardware debug ports
Improved ZRCP:
* run command is stopped by default when pressing a key (or sending data to the socket)
* when a breakpoint is fired on cpu-step-mode, the breakpoint condition is shown on ZRCP
Improved joystick support:
* added joystick test menu
* buttons to events and buttons to joystick configuration are saved on configuration file
Improved OSD keyboard:
* now you can press up to all 40 keys (on Spectrum/ZX80/ZX81) at the same time
* now it can be opened from any place (needs multitask on)
Improved QL emulation:
* experimental support of LOAD, LRUN command
* can now open qlay mdv microdrive image files
Improved file viewer from file utilities:
* specific file viewers for these kind of files: .tap, .zx, .zsf, .sp, .z80, .sna, .spg, .p, .o, .mmc/.ide (fat browser, plus3dos browser), .dsk, .trd, .tzx, .cdt, .flash (zxuno flash, z88 flash, superupgrade flash), .epr, .eprom
* default hexadecimal file viewer for unknown files
* conversion utility
Improved TSConf emulation:
* added TSConf DMA, line interrupt, sprites layers
* TSConf rendering: now tiles and sprites are drawn per scanline. Border drawing. Handling of scroll registers
* TSConf debugging: debug for DMA, Video registers, Video layers, Sprites, Tiles
* added TR-DOS emulation support
Improved menu interface:
* emulated machine display is no longer faded or switched to black & white when opening menu. There were different visual glitches due to this feature
* a new "tabbed" menus to improve usability and interaction with mouse, joystick and stdout driver: waveform, visualmem, ay player
* Character width can be reduced to 7,6 or 5 pixels width
* added a setting to limit menu event: enabling it you should press the menu key 3 times in a second to open the menu
* added a setting to hide directories from file selector menus, useful when you don't want the user to be able to navigate the filesystem
* Smartload: now the cursor remembers last file loaded
* added two more GUI styles: Clean and CleanInverse
Improved sprite viewer:
* now can see sprites with speccy screen format
* you can view sprites up to 512x192
* you can see tsconf sprites
* you can see pseudo hires zx81 screens
Improved TBBlue emulation:
* Added clip window registers
* Added Copper
* Added almost all next extended opcodes
* Added a setting to start TBBlue directly to a 48 rom but with all the Next features enabled, useful for fast snapshot loading
Improved AY Player: now shows waveform volume meter
Improved VU meters with decay effect on AY Player, AY Registers and Waveform
Improved text mode drivers (aalib, stdout, simpletext, curses): text settings are in different submenu, setting to set stdout/simpletext fps
Improved messages windows. You can now have an internal clipboard, press key c to copy to it. Press P on file utils to paste contents to a file
Improved frameskip: better performance, because realvideo buffer is not updated when frameskip
Improved sound: Silence detector activated by default but can be disabled
Improved top speed: loading sound is distorted when setting top speed
Improved autoload: new setting to run at top speed the reset+load"" process
Improved real tape loading: now it shows a percentage of tape loaded
Improved default configuration: when the configuration file doesn't exist, the new one has the autosave configuration setting enabled
Improved configuration parsing: if unknown setting found on configuration file, ZEsarUX will open but warns about the error, and the autosave feature is not enabled
Improved rendering on text mode drivers: now realvideo mode can render directly to black&white text. Try TSConf with --vo stdout --realvideo --autoredrawstdout
Improved Linux library dependencies: libssl is not enabled by default on compilation
Fixed ZX-Uno emulation:
* 128kb timings are the same as a Spectrum 128k. When port 1ffd enabled, port FF return FF
* Kempston port returns 0 when no kempston selected. New BIOS can be used now
Fixed TBBlue MMU when using segment 0000-3FFFH
Fixed Raster interrupts on ZX-Uno and TBBlue. Horizontal raster position was wrong
Fixed window footer when running Pentagon
Fixed panic screen: now it is shown on all machines. New design. I hope you never see it ;)
Fixed some crashes with speech enabled and opening some menus: AY Registers, AY Player, etc...
Fixed annoying sound on Dandanator rom menu
Fixed bug on Z80 cpu core, iff2 was not being reset to 0 when firing an interrupt, so reading it by using LD A,R and LD A,I affected many demos
Some other minor bugfixes and improvements
Espero que os guste!
Cesar
ZEsarUX
iturbez
Sistema Favorito: ZX81
Gracias recibidas: 7 veces
Re: ZEsarUX-7.0
Mensajepor iturbez » 26 May 2018, 08:08
Como siempre, buenas noticias.
Gran trabajo, César.
Un saludo
chernandezba
Re: ZEsarUX-7.0
Mensajepor chernandezba » 26 May 2018, 13:44
iturbez escribió:Como siempre, buenas noticias.
Un saludo
Gracias! :)
ZEsarUX
Gracias recibidas: 27 veces
Re: ZEsarUX-7.0
Mensajepor Bubu » 29 May 2018, 21:25
Hola, chernandezba, y ante todo enhorabuena por el desarrollo, es inmenso el proyecto ;)
Acabo de catar el ZEsarUX-7.0 en un Window$ 7 y se abre, pero no me carga TAP's ni TZX's. ¿Cómo se debe hacer?
chernandezba
Re: ZEsarUX-7.0
Mensajepor chernandezba » 30 May 2018, 12:50
Bubu escribió:Hola, chernandezba, y ante todo enhorabuena por el desarrollo, es inmenso el proyecto ;)
Gracias :)
Menu Smartload
ZEsarUX
Re: ZEsarUX-7.0
Mensajepor Bubu » 30 May 2018, 23:57
La semana que viene probaré eso y te comentaré, a ver qué tal. Thanx!
Re: ZEsarUX-7.0
Mensajepor Bubu » 31 May 2018, 00:22
Una pregunta, chernandezba, ¿el emulador emula al divIDE? Es que me interesa hacer una modificación al FATWARE, y me gustaría poder desarrollarlo y probarlo con un emulador ;)
chernandezba
Re: ZEsarUX-7.0
Mensajepor chernandezba » 01 Jun 2018, 18:55
Bubu escribió:Una pregunta, chernandezba, ¿el emulador emula al divIDE? Es que me interesa hacer una modificación al FATWARE, y me gustaría poder desarrollarlo y probarlo con un emulador ;)
DivIde y Divmmc, por supuesto :) Además también funciona la emulación de escritura en la eeprom desde spectrum, por lo que para probarlo, no tienes ni que modificar los archivos de eeprom de ambos sistemas (esxide085.rom y esxmmc085.rom), sino que lo puedes hacer tal cual lo harías en un Spectrum real
ZEsarUX
chernandezba
Re: ZEsarUX-7.0
Bubu escribió:La semana que viene probaré eso y te comentaré, a ver qué tal. Thanx!
Gracias a ti por usarlo!
ZEsarUX
Re: ZEsarUX-7.0
Mensajepor Bubu » 02 Jun 2018, 20:31
Te quería preguntar, chernandezba, ¿dónde se descarga? Entro en el github que enlazaste, pero sólo veo lo de "Clone or download". Al darle ahí, se pone a descargar un ZIP que cuando iba por 70MB lo he cancelado. ¿Ese es el enlace de descarga? ¿Cuánto ocupa?
Y una curiosidad: ¿qué es eso de "ZX Spectrum Sir Fred running on curses (text) driver"?
Volver a “Emuladores”
