Mensajepor Hark0 » 26 Ene 2015, 10:04
Ole ole y ole!!!!
aowen
Mensajepor aowen » 27 Ene 2015, 15:39
Haplo escribió:Creo que eso también lo comentamos allí, sacar algún juego "zx-uno exclusive" XD
O cuando menos que tuviera una "enhanced version" del mismo para aprovechar las capacidades del zx-uno.
En aumap están colgados los streaming de las conferencias y demás, lo que pasa es que la calidad es flojilla y se escuchan fatal. A ver si tienen tiempo y suben las versiones originales.
I've got a collection of ZX Spectrum SE software that will run on the ZX-Uno in Chloe 280SE mode. The only other ways to run it are in the Fuse emulator or on the prototype machine.
Also I'm planning on doing at least one Chloe 280SE specific demo which will only run on the ZX-Uno. It will feature 6-channel sound, ULAplus raster effects, and disk-streamed animation. Should make quite a good demo video.
Mensajepor mcleod_ideafix » 27 Ene 2015, 17:14
aowen escribió:Also I'm planning on doing at least one Chloe 280SE specific demo which will only run on the ZX-Uno. It will feature 6-channel sound, ULAplus raster effects, and disk-streamed animation. Should make quite a good demo video.
Some time ago, we talked about adding a raster interrupt circuit. That is, to give the programmer the power to decide on which scanline the interrupt should be triggered. How about that?
aowen
Mensajepor aowen » 28 Ene 2015, 16:00
In a few cases it could save a lot of CPU waste. The SAM Coupe has it and it's certainly useful for demos, but also for mixed screen modes where you want to have hi-res and hi-color at the same time (for example Magnetic Scrolls type adventures). As there's not much existing Chloe software at this point I see no harm in adding it, but I would stick it on one of the ZXI ports. Possibly the same range as the CPU speed select. I'd also check with Jeff to see if he's implemented it in the Prism.
Mejias3D
consola_favorita: Videopac
Mensajepor Mejias3D » 30 Ene 2015, 03:57
Nueva revisión de la carcasa para ZX-Uno publicada en Thingiverse aquí
http://www.thingiverse.com/thing:594804
Ahora incluye agujero posterior pensado para la salida de un conector de expansión genérico de 40 pines acodado
(Podéis verlo indicado con una flecha en la imagen inferior del modelo 3D)
Recordad que aquí tenéis algunos detalles extra sobre cómo montar la caja
http://www.zonadepruebas.com//viewtopic.php?f=26&t=5812&start=440#p52285
Lenko
Gracias dadas: 774 veces
Gracias recibidas: 191 veces
Mensajepor Lenko » 30 Ene 2015, 09:33
¡Qué chulada de caja! :shock:
Haplo
Gracias dadas: 33 veces
Gracias recibidas: 5 veces
Mensajepor Haplo » 30 Ene 2015, 11:31
jaja, fantástico, me mola como te ha quedado, aunque ya cualquier cosa me recuerda al vega ese.
Mensajepor radastan » 30 Ene 2015, 11:46
Dos cosas:
1- Estoy elaborando un juego exclusivo para ZX Uno, ya tengo una rutina de sprites, algunos sprites, y me estoy peleando con convertir la paleta y los sprites a binario. A ver si apaño otro portátil (me he cargado el que estaba usando) y puedo continuar con más asiduidad.
2- ¿A qué cartero hay que matar para tener ya el puñetero kit de la V2? Es que esto ya va para meses... se que no es culpa de A. Villena (¡faltaría!) pero es desesperante.
Mensajepor antoniovillena » 30 Ene 2015, 12:16
Ayer me llegaron de golpe todos los paquetes que me faltaban. Voy a intentar empaquetar alguno esta noche para enviarlo mañana. Si no, a partir de la semana que viene
Mensajepor radastan » 30 Ene 2015, 20:09
antoniovillena escribió:Ayer me llegaron de golpe todos los paquetes que me faltaban. Voy a intentar empaquetar alguno esta noche para enviarlo mañana. Si no, a partir de la semana que viene
