Mensajepor antoniovillena » 04 Jun 2015, 08:46
Sinclair escribió:
C:\zxuno\firmware\roms>generamcs.bat > out.txt
El sistema no puede encontrar la ruta especificada.
srec_cat: tld_zxuno_av.mcs: open: No such file or directory
type out.txt
C:\zxuno\firmware\roms>cd ..
C:\zxuno\firmware>call  make.bat
C:\zxuno\firmware>zx7b      logo256x192.rcs       logo256x192.rcs.zx7b
File logo256x192.rcs.zx7b compressed from logo256x192.rcs (6912 to 381 bytes)
C:\zxuno\firmware>sjasmplus firmware.asm
SjASMPlus Z80 Cross-Assembler v1.07 RC7 (build 02-04-2008)
Pass 1 complete (0 errors)
Pass 2 complete (0 errors)
Pass 3 complete
Errors: 0, warnings: 0, compiled: 3853 lines, work time: 0.031 seconds
C:\zxuno\firmware>fcut      firmware_strings.rom  8000 -8000  strings.bin
0xD87 bytes written (3463) at offset 0x8000 (32768)
C:\zxuno\firmware>zx7b      strings.bin           strings.bin.zx7b
File strings.bin.zx7b compressed from strings.bin (3463 to 1541 bytes)
Pass 3 complete
C:\zxuno\firmware>fcut      firmware_strings.rom  0000  4000  firmware.rom
0x4000 bytes written (16384) at offset 0x0 (0)
C:\zxuno\firmware>cd roms
C:\zxuno\firmware\roms>..\sjasmplus aa000.asm
Pass 3 complete
Errors: 0, warnings: 0, compiled: 195 lines, work time: 0.000 seconds
C:\zxuno\firmware\roms>copy /b ESXMMC.BIN+                           aa000.bin+                            ..\firmware.rom+                      48.rom+                               plus3es40zxmmc.rom+                   se.rom+                               leches.rom+                           ManicMiner.rom+                       JetSetWilly.rom+                      LalaPrologue.rom+                     Deathchase.rom+                       Chess.rom+                            Backgammon.rom+                       HungryHorace.rom+                     HoraceSpiders.rom+                    Planetoids.rom+                       SpaceRaiders.rom+                     MiscoJones.rom                    roms_a8000.bin
ESXMMC.BIN
aa000.bin
..\firmware.rom
48.rom
plus3es40zxmmc.rom
se.rom
leches.rom
ManicMiner.rom
JetSetWilly.rom
LalaPrologue.rom
Deathchase.rom
Chess.rom
Backgammon.rom
HungryHorace.rom
HoraceSpiders.rom
Planetoids.rom
SpaceRaiders.rom
MiscoJones.rom
        1 archivo(s) copiado(s).
C:\zxuno\firmware\roms>rem call promgen  -w -spi -p mcs -o tld_zxuno_es.mcs       ^
C:\zxuno\firmware\roms>rem               -s 4096 -u 0 ..\..\cores\spectrum_v2_spartan6\test14\tld_zxuno_es.bit
C:\zxuno\firmware\roms>call promgen  -w -spi -p mcs -o tld_zxuno_av.mcs                        -s 4096 -u 0 ..\..\cores\spectrum_v2_spartan6\test15\tld_zxuno.bit
C:\zxuno\firmware\roms>\zz\Xilinx\12.1\ISE_DS\ISE\bin\nt64\promgen.exe -w -spi -p mcs -o tld_zxuno_av.mcs                        -s 4096 -u 0 ..\..\cores\spectrum_v2_spartan6\test15\tld_zxuno.bit
C:\zxuno\firmware\roms>rem srec_cat  tld_zxuno_es.mcs   -Intel                 ^
C:\zxuno\firmware\roms>rem           roms_a8000.bin  -binary -offset 0xa8000   ^
C:\zxuno\firmware\roms>rem           -o prom_es.mcs     -Intel                 ^
C:\zxuno\firmware\roms>rem           -line-length=44                           ^
C:\zxuno\firmware\roms>rem           -line-termination=nl
C:\zxuno\firmware\roms>srec_cat  tld_zxuno_av.mcs   -Intel                           roms_a8000.bin  -binary -offset 0xa8000             -o prom_av.mcs     -Intel                           -line-length=44                                     -line-termination=nl
C:\zxuno\firmware\roms>srec_cat  prom_av.mcs     -Intel               -o tld_zxuno.bin  -binary
C:\zxuno\firmware\roms>rem ..\fcut tld_zxuno.bin 54000 5c000 machine.bin
C:\zxuno\firmware\roms>..\fcut tld_zxuno.bin 00000 54000 machine1.bin
0x54000 bytes written (344064) at offset 0x0 (0)
C:\zxuno\firmware\roms>..\fcut tld_zxuno.bin a8000 08000 machine2.bin
0x8000 bytes written (32768) at offset 0xA8000 (688128)
C:\zxuno\firmware\roms>copy /b machine1.bin+machine2.bin machine.bin
machine1.bin
machine2.bin
C:\zxuno\firmware\roms>GenRom 0 202 0 0 0 'BIOS' ..\firmware.rom firmware.tap
File generated successfully
C:\zxuno\firmware\roms>GenRom 0 0 0 0 0 'ESXDOS' ESXMMC.BIN  esxdos.tap
C:\zxuno\firmware\roms>GenRom 0 0 0 0 0 'Machine' machine.bin  machine.tap
C:\zxuno\firmware\roms>CgLeches firmware.tap firmware.wav
C:\zxuno\firmware\roms>CgLeches machine.tap  machine.wav
Pues tiene pinta de haber funcionado bien. No me concuerda la primera línea de error de srec_cat, pero según lo demás el archivo machine.tap se te debe haber generado correctamente.
Sinclair
Gracias dadas: 8 veces
Mensajepor Sinclair » 04 Jun 2015, 09:03
type out.txt
Pass 3 complete
Pass 3 complete
Pass 3 complete
ESXMMC.BIN
aa000.bin
..\firmware.rom
48.rom
plus3es40zxmmc.rom
se.rom
leches.rom
ManicMiner.rom
JetSetWilly.rom
LalaPrologue.rom
Deathchase.rom
Chess.rom
Backgammon.rom
HungryHorace.rom
HoraceSpiders.rom
Planetoids.rom
SpaceRaiders.rom
MiscoJones.rom
machine1.bin
machine2.bin
No, si el machine.tap lo genera y otros archivos más, el problema es que no genera el .mcs.
© 1982 Sinclair Research Ltd
Gracias recibidas: 17 veces
Mensajepor Quest » 04 Jun 2015, 09:14
Sinclair escribió:No, si el machine.tap lo genera y otros archivos más, el problema es que no genera el .mcs.
Edita promgen.bat y cambia esta linea:
\zz\Xilinx\12.1\ISE_DS\ISE\bin\nt64\promgen.exe %*
cambia \zz\ por la unidad donde tienes instalado el ISE, y el 12.1 por la versión que tengas instalada (en mi caso es la 12.1 asi que no lo toco).
Sinclair
Mensajepor Sinclair » 04 Jun 2015, 09:23
Sin duda apuntaba mal, pero ahora un error más, que supongo que será por la versión que tengo instalada (Xilinx ISE 8.2i):
ERROR:Bitstream:14 - The device part "6slx9tqg144" specified in the bitstream
   file "../../cores/spectrum_v2_spartan6/test15/tld_zxuno.bit" is invalid.
   This file may be corrupted and should be recreated.
FATAL_ERROR:Bitstream:basbsbitfile.c:93:1.47.24.3 - Cannot load bitfile.
   Process will terminate.  To resolve this error, please consult the Answers
   Database and other online resources at http://support.xilinx.com. If you need
   further assistance, please open a Webcase by clicking on the "WebCase" link
C:\zxuno\firmware\roms> type out.txt
Pass 3 complete
Pass 3 complete
Pass 3 complete
0.bin
ESXMMC.BIN
aa000.bin
..\firmware.rom
48.rom
plus3es40zxmmc.rom
se.rom
leches.rom
ManicMiner.rom
JetSetWilly.rom
LalaPrologue.rom
Deathchase.rom
Chess.rom
Backgammon.rom
HungryHorace.rom
HoraceSpiders.rom
Planetoids.rom
SpaceRaiders.rom
MiscoJones.rom
t
C:\zxuno\firmware\roms>ECHO \zz\Xilinx\12.1\ISE_DS\ISE\bin\nt64\promgen.exe -w -
ld_zxuno.bit
C:\zxuno\firmware\roms>E:\PROGRAMAS\Xilinx\bin\nt\promgen.exe -w -spi -p mcs -o
Release 8.2i - Promgen I.31
Copyright (c) 1995-2006 Xilinx, Inc.  All rights reserved.
el                           -line-length=44
no.bin  -binary
machine1.bin
machine2.bin
-- Actualizado 04 Jun 2015, 10:44 --
Instalando versión 14...
Quiero generar el firmware con la configuración de teclado ES en lugar de la AV
cd ..
call  make.bat
cd roms
copy /b ESXMMC.BIN+                   ^
        aa000.bin+                    ^
        ..\firmware.rom+              ^
        48.rom+                       ^
        plus3es40zxmmc.rom+           ^
        se.rom+                       ^
        leches.rom+                   ^
        ManicMiner.rom+               ^
        JetSetWilly.rom+              ^
        LalaPrologue.rom+             ^
        Deathchase.rom+               ^
        Chess.rom+                    ^
        Backgammon.rom+               ^
        HungryHorace.rom+             ^
        HoraceSpiders.rom+            ^
        Planetoids.rom+               ^
        SpaceRaiders.rom+             ^
        MiscoJones.rom                ^
    roms_a8000.bin
call promgen  -w -spi -p mcs -o tld_zxuno_av.mcs          ^
srec_cat  tld_zxuno_av.mcs   -Intel                 ^
          -o prom_av.mcs     -Intel                 ^
          -line-length=44                           ^
srec_cat  prom_av.mcs     -Intel     ^
Supongo que será tan simple como descomentar esta línea:
y comentar esta otra:
¿pero entonces esta otra posterior por cual la sustituyo?
-- Actualizado 04 Jun 2015, 11:20 --
Bien. Con la versión 14 genera el .mcs correctamente.
Para hacer que me coja la configuración de telcado "ES" he dejado el generamcs.bat así:
cd ..
call  make.bat
cd roms
        aa000.bin+                    ^
        ..\firmware.rom+              ^
        48.rom+                       ^
        se.rom+                       ^
        leches.rom+                   ^
        ManicMiner.rom+               ^
        JetSetWilly.rom+              ^
        LalaPrologue.rom+             ^
        Deathchase.rom+               ^
        Chess.rom+                    ^
        Backgammon.rom+               ^
        HungryHorace.rom+             ^
        Planetoids.rom+               ^
        SpaceRaiders.rom+             ^
        MiscoJones.rom                ^
    roms_a8000.bin
rem call promgen  -w -spi -p mcs -o tld_zxuno_av.mcs          ^
rem              -s 4096 -u 0 ..\..\cores\spectrum_v2_spartan6\test15\tld_zxuno.bit
          -line-length=44                           ^
rem srec_cat  tld_zxuno_av.mcs   -Intel                 ^
rem          -o prom_av.mcs     -Intel                 ^
srec_cat  prom_es.mcs     -Intel     ^
Y la salida ahora es esta:
C:\zxuno\firmware\roms>generamcs_ES.bat > out.txt
ERROR:Bitstream:51 - Unable to read file
   "../../cores/spectrum_v2_spartan6/test14/tld_zxuno_es.bit".  Either the
   specified directory path does not exist or the file does not have readable
   permissions.
ERROR:Bitstream:53 - Missing or invalid bit files found after the -u option.
srec_cat: tld_zxuno_es.mcs: open: No such file or directory
Mensajepor antoniovillena » 04 Jun 2015, 11:21
El nombre del archivo da igual, mientras el tld_zxuno.bit haya sido compilado con el teclado ES te debería funcionar. Y en el repositorio ese .bit tiene teclado ES.
Sinclair
Mensajepor Sinclair » 04 Jun 2015, 11:21
Acabo de añadir más información.
-- Actualizado 04 Jun 2015, 11:31 --
Pues que bien... con el nuevo firmware generado por mi mismo (antes de hacer los cambios en el .bat) he actualizado sin problemas pero al generar un NMI (CTRL+ALT+F5) me hace un bonito reset en lugar de sacarme el menú de ESXDOS.
-- Actualizado 04 Jun 2015, 11:40 --
Efectivamente, veo que me ha cargado la configuración de teclado ES porque ahora F2 ha adquirido la función EDIT.
La combinación de teclas para general NMI no debe ser la misma y por eso no me funciona, ¿pero generar un reset en su lugar?... me extraña.
Estoy "rebuscando" a ver si encuentro cual es la combinación para la generación de un NMI en esta versión ...
Mensajepor mcleod_ideafix » 04 Jun 2015, 11:54
Sinclair escribió:Efectivamente, veo que me ha cargado la configuración de teclado ES porque ahora F2 ha adquirido la función EDIT.
En el teclado ES, la tecla F2 es de hecho EDIT. Creo que en el AV también. Es de hecho la forma de entrar a la BIOS.
Mensajepor Quest » 04 Jun 2015, 12:08
La combinación de NMI no ha cambiado. De hecho, el hecho de que "haga un reset" indica que la combinación está bien. Revisa estos puntos:
- Tienes activadas en la BIOS las opciones de divMMC y divMMC NMI, o bien las tienes en auto y eliges arrancar con una ROM que lleve ambos valores activados por defecto.
- Tienes la tarjeta SD bien metida (a veces me pasa que se me sale un poco y tengo que volver a apretarla) y con los archivos correctos de ESXDOS.
Sinclair
Mensajepor Sinclair » 04 Jun 2015, 12:08
Pues entonces el motivo por el que no carga ESXDOS es otro.
Sinclair
Mensajepor Sinclair » 04 Jun 2015, 12:11
La configuración la tengo así y ha respondido bien con versiones anteriores.
-- Actualizado 04 Jun 2015, 13:35 --
Nada, ...debe haber algo mal en esta compilación tal y como se genera desde los archivos de repositorio.
Podéis probar alguno para confirmarlo.
Mientras tanto agradecería que alguien me pasara un .mcs válido de la versión 0.226.
Gracias.
