benkenobi
Gracias recibidas: 13 veces
Mensajepor benkenobi » 14 Jul 2015, 00:26
Encuanto mañana arregle el desastre de mesa que he dejado hago fotos y me descargo los juegos/demos.
Mensajepor Hark0 » 14 Jul 2015, 09:27
mcleod_ideafix escribió:
benkenobi escribió:Buenas! Mi zxuno vive!!!!
Fotoooooooooos :)
En la carpeta "software" del repositorio tienes demos y juegos para probarlo.
La "cinta demo matrix" ande anda? :P (sí, soy un cansino).
Mensajepor mcleod_ideafix » 14 Jul 2015, 11:07
Fotoooooooooos :)
En "software/ulaplus"
chernandezba
consola_favorita: NeoGeo
Gracias recibidas: 179 veces
Mensajepor chernandezba » 14 Jul 2015, 12:10
Ale, pues yo también queria saber donde estaba la demo de Matrix, y ya lo he podido probar con mi emu :)
ZEsarUX
aowen
Mensajepor aowen » 15 Jul 2015, 11:14
Just to let you know, I've ordered the prototype Chloe 280SE keyboard. I'll post some pics when it arrives. Also, a colleague recommend this PCB manufacturer. I believe they will do assembly as well. http://imall.itead.cc/
Mensajepor mcleod_ideafix » 15 Jul 2015, 12:20
aowen escribió:Just to let you know, I've ordered the prototype Chloe 280SE keyboard. I'll post some pics when it arrives. Also, a colleague recommend this PCB manufacturer. I believe they will do assembly as well. http://imall.itead.cc/
That's great news! About the PCB manufacturing, we would like to have it made in Spain, or at least in EU, to avoid import duties and the like. Also, having the board assembled in Spain allows us to review the process and talk with the engineers at the factory person to person. After all, it won't be our money, but crowfunder's, and managing other's money is always a delicate issue.
Mensajepor Hark0 » 15 Jul 2015, 13:07
aowen escribió:.... I'll post some pics when it arrives....
Please,.... ;)
(about the prize of these keyboard... are expensive?)
aowen
Mensajepor aowen » 15 Jul 2015, 13:16
I understand. I'm inclined to get the boards for the Chloe made in the UK for similar reasons. But the keyboards are costing more than a ZX Spectrum Vega, so I may have no choice but to go to Hong Kong to keep the overall price down.
aowen
Mensajepor aowen » 20 Jul 2015, 12:32
Please,.... ;)
Not as expensive as customizing this keypad: http://www.adesso.com/products/product-detail-125.html
It will be worth it though.
Gracias recibidas: 17 veces
Mensajepor Quest » 20 Jul 2015, 14:12
mcleod_ideafix escribió:Mientras Antonio prepara el soporte para la NMI especial del TEST 17, os presento el inenarrable e inconmensurable...
TEST 18
En este core por fin tenemos soporte para raton Kempston, que era una de las cosas que faltaba por poner en el core "oficial" desde el principio.
Para conectar el ratón y el teclado al único conector PS/2 que hay en el ZX-Uno se necesita un cable "splitter"
Hoy he decidido meter el Test18 al ZX-UNO dado que ya me ha llegado el splitter PS/2, y quería probarlo.
El problema es que una vez grabado, no hay manera de que arranque bien el ZX-UNO, es muy inestable y da continuamente glitches gráficos, cuelgues y reseteos. ESXDOS queda corrupto y no detecta archivos (eso cuando salta ESXDOS, que es una de cada 10 veces), etc, etc.
He comprobado varias veces la grabación de la SPI, el firmware, ESXDOS, está todo correcto, byte a byte. De hecho si vuelvo a grabar el Test17 todo vuelve a ir perfectamente.
¿Qué puede estar pasando?
Un par de fotos de ejemplo:
