Otro IBM más
Perro
Otro IBM más
Mensajepor Perro » 01 Feb 2013, 19:09
Buenas
Pues he adquirido un nuevo "cacharro" para mi colección. Esta vez ha sido el turno de un IBM 300GL, que acompañará al ya restaurado IBM PS1.
Me ha llegado hoy, lo he probado y funciona. Tiene WinXP y parece que va bien, aunque estoy pensando meter el Win98, sobretodo por las características del PC (las he sacado del manual PDF):
Model* IBM PC 300GL (6287) IBM PC 300GL (6275 or 6285)
Celeron processor 433, 400, 366 or 333MHz 433, 366 or 333MHz
L2 cache-pipeline burst 128KB 128KB
Core chipset Intel 440BX AGP4 Intel 440BX AGP
SDRAM (std/max) 64 or 32MB/256MB 64 or 32MB/256MB
DIMM slots 2 2
Video graphics S3 Trio3D AGP S3 Trio3D AGP
Std/max memory 2MB/4MB SGRAM 2MB or 4MB/4MB SGRAM
S.M.A.R.T. hard disk drives 8.4 or 4.2GB5 Ultra ATA 8.4 or 4.2GB Ultra ATA
Form factor 4x4 microtower 4x4 desktop or 6x6 minitower
(WxDxH) 194mmx381mmx381mm 450mmx450mmx128mm or
200mmx445mmx492mm
Slots 3 PCI, 1 ISA 2 PCI/ 1 ISA/ 1 shared or
3 PCI and 3 ISA
Ports/drives 1 video, 1 serial (6287) or 2 serial (6275 or 6285),
1 enhanced parallel (ECP/EPP), 2 USB, 10/100 Ethernet RJ-45
(select models), 32X-14X CD-ROM drives (select models),6
Ultra ATA controller supports 4 devices, 1 keyboard, 1 mouse
Universal Manageability Technology enablers: Asset Information Chip,
S.M.A.R.T. hard disk drives, Wake on LAN enabled;
Lifecycle tools: Asset registration, Client Services for
Netfinity Manager™, ConfigSafe®, CoSession Remote 32,
DMI v2.0 compliant, EZAdmin, LANDesk® Client Manager,
WfM 1.1a compliant, LANClient Control Manager support,
Norton AntiVirus™ (OEM Version),7 PC-Doctor, Plug and Play
compliant, SMART Reaction, System Update, Tivoli®-ready,
Universal Management AgentTM (UMA) and UMA Plus enabled
Productivity tools Microsoft® Windows NT®, Microsoft Windows® 98, Lotus®
SmartSuite® CD,8 IBM ViaVoice 98 Office™(6287), Internet
Explorer 4.0, IBM Product Recovery CD, Software Selection CD
(6287), Ready to Configure CD (6275 or 6285)
Options 6X DVD-ROM Internal IDE Option Kit (20L0550); 2x/4x/24x CDRW
Internal IDE Option Kit (20L0551);TR5 10/20 GB Internal IDE
Tape Drive (20L0549); 16MB-128MB NP SDRAM (01K1134-38);
Zip 100MB internal drive (20L0544); 10/100 Fast EtherLink® XL
Adapter with Remote Wake-Up by 3Com® (34L1001); IBM P72
17"/16" VIS or IBM G54 15"/13.7" VIS color monitors (655603N or
65460AN); v.90 Internet Modem Kit (10L7389). Please visit
http://www.ibm.com/pc/us/accessories for a complete list of
compatible options.
Standards supported FCC Part 15, Class B (Class A when Ethernet in use); UL 1950
First Edition, CSA c22.2 No. 950; ISO 9241 capable;
ANSI S12.10
Unas fotillos:
Se le ve en buen estado. Trae cpu, monitor y teclado. Me falta el ratón.
Me encanta el diseño de estos "bichos"
Aquí me va a tocar limpiar y dejarlo unos días al solo con un poco de agua oxigenada, jeje.
¿Qué os parece?
Re: Otro IBM más
Mensajepor na_th_an » 01 Feb 2013, 19:52
Precioso :)
Depende de para qué lo vayas a utilizar, pero yo le pondría Windows 2000 SP4, me parece un hardware que se beneficiaría de sus características.
Perro
Re: Otro IBM más
Mensajepor Perro » 01 Feb 2013, 19:55
na_th_an escribió:Precioso :)
Gracias por el consejo.
Eso sí, ¿dónde puedo conseguir un win2000 sp4?
Mad Marx
Re: Otro IBM más
Mensajepor Mad Marx » 02 Feb 2013, 14:53
son chulísimos, yo tuve 2 CPU como esa que acabé tirando por desuso, ahora me arrepiento, mucho.
LoneJoeSilver
Dragon 32
Dragon 32
Re: Otro IBM más
Mensajepor LoneJoeSilver » 02 Feb 2013, 15:01
La verdad es que el modelo es muy chulo y está impoluto.
Un amigo tenía el mismo modelo y la verdad es que iban muy bien.
Felicidades por la compra.
Un saludo
Perro
Re: Otro IBM más
Mensajepor Perro » 04 Feb 2013, 20:22
Os pongo las características del modelo (sacadas a través del Everest):
- Pentium III 667mhz
- Placa - IBM6563W2G
- Memoria 128 (SDRAM)
- Tarjeta gráfica S3 Savage 4 (8 mb)
- Disco duro 15 gb
- LG Cd-rom 40x
- Windows XP
¿Qué sistema operativo me recomendáis?
Manualeitor
Re: Otro IBM más
Mensajepor Manualeitor » 02 Mar 2013, 15:17
Vaya, todo un Pentium III. Pues dependiendo de la RAM yo creo que con un XP debe de ir bien, pero mejor tal vez 2000 como te comentan, o en su defecto cualquier Linux. Esas máquinas son realmente preciosas, sí señor. Muy buena compra. ¡Quien la pillara! :)
Yo tengo un ratón IBM, pero es el de mi PS/2 Modelo 30 y no tengo ganas de deshacerme de él. Pero también tengo un ratón Microsoft de los que van inalámbricos y parecen así como una especie de "casita". Raro y bien cuidado, y funciona perfecto. Ya pondré fotos. :)
¡Abrazos!
Manu
tera00
Re: Otro IBM más
Mensajepor tera00 » 10 Mar 2013, 00:11
Con un Windows XP de bajo consumo de recursos (llevan desactivados muchos servicios innecesarios) creo que se le puede sacar mas partido a ese IBM, da más posibilidades en cuanto a conectividad y multimedia, aunque siempre haciendo referencia a datos que se movian en esa época.
Pero es sólo un consejo.
Es imposible desengancharme de este 'VICIO'
Re: Otro IBM más
Mensajepor scooter » 10 Mar 2013, 00:35
Lo malo es que suelen ser muy punteros para reconocer la RAM, mi mujer tenia uno y solo aceptaba su RAM, no reconoció ninguna otra
Panaka
Re: Otro IBM más
Mensajepor Panaka » 10 Mar 2013, 12:12
Yo soy de la idea que si es para colección que pongas el sistema de origen del pc cuando se fabrico.
Es un equipo que no necesitas tenerlo a la ultima.
