Tipografia de 8 bits
Zardoz
Mensajepor Zardoz » 29 May 2014, 23:38
My love of typography originated in the 80′s with the golden years of 8-bit home computing and their 8×8 pixel mono-spaced fonts on low-resolution displays.
It’s quite easy to find bitmap copies of these fonts and also scalable traced TTF versions but there’s very little discussion about the fonts themselves. Let’s remedy that by firing up some emulators and investigating the glyphs.
http://damieng.com/blog/2011/02/20/typo ... stem-fonts
Yep, I have a blog :zardoz.es
Emulador DCPU-16 VM
Emulador Trillek
UFO
Gracias dadas: 43 veces
Gracias recibidas: 4 veces
Re: Tipografia de 8 bits
Mensajepor UFO » 30 May 2014, 09:00
Gracias por el aporte, zardoz! :jumper:
