Can Help me find decent DMX light for Latest project
bohan131411
Sistema Favorito: C16
primer_sistema: Amstrad PCW
Mensajepor bohan131411 » 16 Oct 2014, 05:32
Hey there... I decided that I've gotta get a sort of stage lights together before the new
academic year starts Oct 30th... but in order to do that, I'd need some decent moving head
light- with good dimming and high power for outside using.I'd like to use them for many years. It must be able to smooth scanning,horizontal scan 540 degrees, 260 degrees vertical scanning. Is there anything I can buy in let's say roughly $100 range? Any body knows where I can find those kind decent lights? Anybody can give me some advice. Thanks in advance. :jumper: :gamers: :gamers:
bohan131411
Re: Can Help me find decent DMX light for Latest project
Mensajepor bohan131411 » 17 Oct 2014, 05:38
Hey guys.i am going for a moving head light. i don't really know a lot about stage lighitng
equipments and stuff, so i thought you guys could help me out. i found two that, to me look
appealing:
http://www.stagelasers.com/221-single-green-laser-light-show-with-eight-heads-diode-pumped-solid-state or
http://www.stagelasers.com/newest-bright-1615w-4in1-osram-led-beam-moving-head-light-with-152679-channels :-k I'm gonna to use the light for several years through it.Is there anything I can buy, let's say
roughly $100 range? if you have a better option for around the same price range please let me
know. thanks guys!
Mensajepor jepalza » 17 Oct 2014, 07:12
Foro Español, por favor, escribe en Español, que no todo el mundo entiende. Si puedo te ayudaré, pero solo si te entiendo.
telekita
Mensajepor telekita » 17 Oct 2014, 10:03
Publicidad encubierta?
Mensajepor princemegahit » 17 Oct 2014, 10:40
Closed by precaution. If it isn't spam and you are a human being and not a robot, contact with me by private message.
Volver a “Microordenadores”
