Atari 600XL
Gracias dadas: 277 veces
Gracias recibidas: 161 veces
Atari 600XL
Mensajepor nandove » 26 Sep 2016, 09:32
Pues al amigo Gameover le pille un flamante Atari 600XL, siempre me gustó este micro porque es muy compacto(no tanto como mi querido Oric :p ) y tiene un aspecto de lo mas retro.
Pero para sacarle el máximo a este pequeño hay que hacerle un par de modificaciones, la Ram a 64kb, y el vídeo compuesto, ya que esta unidad solo trae antena.
he seguido para el vídeo el siguiente tutorial:
https://atrey.karlin.mff.cuni.cz/~pavel ... xlmon.html
y aunque no se ve mal del todo, queda un pelin oscuro para mi gusto :/
Para el mod de la ram seguí este otro que estaba en una pagina de Atarimax:
HOW TO UPGRADE YOUR ATARI 600XL TO 64K RAM
THIS MOD IS COPYRIGHTED BY KEN SUMRALL. HOWEVER, YOU MAY FREELY
DISTRIBUTE IT, AND MODIFY IT, AS LONG AS THIS NOTICE IS INCLUDED
IN ITS ENTIRERTY. THE AUTHOR MAY BE REACHED AT THE FOLLOWING
EMAIL ADDRESSES:
ken%hpda@hplabs.hp.com
...!hplabs!hpda!ken
You will need the follow parts to perform this mod:
(2) 4464 RAM chip, 64Kx4, 150ns or faster.
Additionally, you will need chip pullers, a soldering iron, and 3 small
pieces of wire. I used wire wrap wire when I did this mod.
If the chips on your 600XL are socketed, you're in luck, otherwise, you need to
first unsolder the following chips:
(1) 74S32 location U18
(2) 74LS158 locations U5 and U6
(2) 4416 locations U11 and U12
and put sockets on the mother board in their place to make the job easier.
Now bend up pin 9 on the 74S32, and put it back in its socket on
the mother board. Bend up pin 3 on the 74LS158 in location U5, and put it
back in its socket. Also, bend up pin 10 on the 74LS158 in location U6,
and put that chip back into its socket. The last two chips you need to
change are the two RAM chips. Put the 4464 chips into the sockets at
locations U11 and U12 on the motherboard.
Now you need to install 3 wires to complete the mod. The first wire should
be connected between pin 3 of the 74LS158 at location U5, and pin 20
of the parallel bus on the 600XL. The second wire should be connected between
pin 10 of the 74LS158 at location U6, and pin 18 of the parallel bus.
The third wire connects between pin 9 of the 74S32 at location U18, and
pin 45 on the parallel bus. That's all there is to it.
Edit: podria fotos, pero no se adjuntarlas >|
weezerand
Sistema Favorito: Atari 800XL/600XL
Re: Atari 600XL
Mensajepor weezerand » 26 Sep 2016, 13:36
Una máquina incomprendida en muchos sitios... snif snif!
Ya estaria bien hacer un pequeño tutorial del proceso... En mi caso poseo un 800XL al cual intento sacar partido... que ya saqué de tierno infante cuando me dedicaba cual poseso a estar dias enteros encima del teclado dale que te pego para conseguir programar algunas cosillas...
Saludancias
Re: Atari 600XL
Mensajepor nandove » 26 Sep 2016, 15:40
weezerand escribió:Una máquina incomprendida en muchos sitios... snif snif!
Saludancias
A todo el mundo que tiene un Atari de 8 bits, le recomiendo encarecidamente este producto de Lotharek:
http://lotharek.pl/product.php?pid=68
Es barato y hace de todo.
amakuja
Gracias dadas: 26 veces
Gracias recibidas: 146 veces
Re: Atari 600XL
Mensajepor amakuja » 26 Sep 2016, 17:40
Éste fue el primer cacharro con el que empecé a darle a la tecla con 7-8 años. En realidad era de mi padre y tenía el módulo de memoria externa. Conservo todo menos la caja y los juegos/programas que venían en casette. De vez en cuando lo enchufo y le cargo algún juego en mp3.
Tengo otro que da un pantallazo negro al enchufarlo, pero que queda muy bien como decoración :lol: .
Mi lista de la compra...
explorer
Sistema Favorito: Atari ST
Gracias recibidas: 184 veces
Re: Atari 600XL
Mensajepor explorer » 26 Sep 2016, 22:44
Con mi 800 XL conseguí dominar la técnica de adaptar programas del ZX Spectrum de la revista Microhobby. ¡Incluso los gráficos definidos por el usuario!
TeníanTienen un hardware muy, muy interesante. Lástima de la falta de información que teníamos en aquella época.
weezerand
Re: Atari 600XL
Mensajepor weezerand » 28 Sep 2016, 13:23
explorer escribió:Con mi 800 XL conseguí dominar la técnica de adaptar programas del ZX Spectrum de la revista Microhobby. ¡Incluso los gráficos definidos por el usuario!
En su momento me dedicaba a la programación gráfica utilizando el Atari... Consiguiendo cosillas como animar logos al estilo Lucasfilm (Ballblazer entre otros) y a lelgar a programar una aventura conversacional con graficos dibujados ](*,) a mano ](*,) sobre el juego Space Ace... que no tiré de fotocopias de Micromania por dios... hasta que el pequeñin ardió (literalmente) en mis manos...
Saludancias
Re: Atari 600XL
Mensajepor nandove » 28 Sep 2016, 13:35
Pues os comento que aunque la salida de video funciona, no estoy conforme con ella, se ve con poca ganancia, oscura...
Estoy intentando mejorarlo. :-({|=
Gracias dadas: 1515 veces
Gracias recibidas: 2567 veces
Re: Atari 600XL
Mensajepor alt » 28 Sep 2016, 16:58
weezerand escribió:En su momento me dedicaba a la programación gráfica utilizando el Atari... Consiguiendo cosillas como animar logos al estilo Lucasfilm (Ballblazer entre otros) y a lelgar a programar una aventura conversacional con graficos dibujados ](*,) a mano ](*,) sobre el juego Space Ace...
¿Y eso no lo tienes preservado? :)
Gracias dadas: 1243 veces
Gracias recibidas: 271 veces
Re: Atari 600XL
Mensajepor robcfg » 28 Sep 2016, 17:40
A mi también me gustaría probarlo en mi 800XL!
marcos64
Gracias dadas: 59 veces
Gracias recibidas: 33 veces
Re: Atari 600XL
Mensajepor marcos64 » 28 Sep 2016, 21:41
Yo tenia entendido que todos los 600XL PAL tenian salida de video compuesto, que eran los 600XL NTSC los que solo tenian salida por antena. Entonces no es asi? O quizas es al reves?
http://marcos64.orgfree.com/
