ZEsarUX-7.1 BETA
chernandezba
consola_favorita: NeoGeo
Gracias recibidas: 179 veces
ZEsarUX-7.1 BETA
Mensajepor chernandezba » 13 Ago 2018, 11:01
Hola
He subido una nueva versión BETA de ZEsarUX 7.1 aqui:
https://github.com/chernandezba/zesarux ... 1-10082017
Cambios de esta version:
Added ACB/ABC/BAC/Custom Stereo emulation
Improved menu windows: now can have more lines than 22, doing scroll
Added joystick action to change emulated joystick type: Sinclair, Kempston, etc
Added support to show some unicode (utf8) characters on menu
Added Basic viewer for .bas basic files (plain ascii or Basic Spectrum data with tokens), .baszx80 (Basic ZX80 with tokens), .baszx81 (Basic ZX81 with tokens), Z88 basic files with tokens
Added ZXUno DMA emulation
Added TBBlue/DataGear/MB02 DMA emulation
Added Beeper Piano Menu
Added new Z80 TBBlue opcodes and deleted obsolete ones
Added setting to change Kempston Mouse sentitivity
Improved debugger:
*Added bitwise operators AND (&), OR (|), XOR (^) when using registers breakpoints/watches
*New pseudo variables:
**OUTFIRED: returns 1 if last Z80 opcode was an OUT operation
**INFIRED: returns 1 if last Z80 opcode was an IN operation
**INTFIRED: returns 1 when an interrupt has been generated
* breakpoints actions do not reset keyboard
Improved menu:
* now you can write any ascii character on the menu
* now you can use binary numbers on expressions
* you can now scroll with mouse on windows with text contents and file selector menus, by clicking the right progress symbol (*)
* now you can move cursor up/down with mouse on windows with text contents and file selector by clicking new arrow buttons
* new file expander on file selector menu, using space key, for the following file types : .tap, .tzx, .dsk, .trd, .mdf, .hdf, .P, .O, Z88 Cards (.epr, .eprom, .flash)
Fixed autoload tape on TBBlue
Fixed bug when smartload and selecting an unknown file type: if you cancel it, the inserted tape was modified
Fixed bug reading extension on files with no extension
Fixed bug reading AY registers: unused bits for registers are set to 0
Fixed bugs on esxdos handler:
*readdir call was incrementing PC register when there was no more files
*added ESXDOS_MODE_CREAT_TRUNC mode when opening files
*BCDE was not returning from a f_seek call
Updated to the last Next SD image
Some other minor bugfixes and improvements
Espero que os guste!
Cesar
ZEsarUX
iturbez
Sistema Favorito: ZX81
Gracias dadas: 11 veces
Gracias recibidas: 8 veces
Re: ZEsarUX-7.1 BETA
Mensajepor iturbez » 13 Ago 2018, 15:00
Cómo siempre, buenas noticias.
Gracias por tu trabajo, César.
A descargar y a probar.
chernandezba
Mensajepor chernandezba » 13 Ago 2018, 15:44
iturbez escribió:Cómo siempre, buenas noticias.
Gracias a ti por probarlo :D
ZEsarUX
josepzin
Gracias recibidas: 70 veces
Mensajepor josepzin » 13 Ago 2018, 19:49
Seguramente en la documentación esté especificado pero aprovecho el hilo :P
¿Cómo se hace para que el emulador inicie a pantalla completa y que cargue un juego enviado por linea de comandos?
Última edición por josepzin el 14 Ago 2018, 00:08, editado 1 vez en total.
Mensajepor Bubu » 13 Ago 2018, 23:13
chernandezba, cuando saques una versión con lo del fullscreen corregido avísame que seré el primero en catarlo y usarlo a jierro ;)
chernandezba
Mensajepor chernandezba » 14 Ago 2018, 09:18
josepzin escribió:Seguramente en la documentación esté especificado pero aprovecho el hilo :P
Pues tal cual:
--fullscreen juego
Te recomiendo que lo ejecutes con
--help
y
--experthelp
Esto funciona como cualquier programa de Linux/Unix, un --help te da la ayuda. No lo habías probado?
ZEsarUX
chernandezba
Mensajepor chernandezba » 14 Ago 2018, 09:19
Bubu escribió:chernandezba, cuando saques una versión con lo del fullscreen corregido avísame que seré el primero en catarlo y usarlo a jierro ;)
Ok, quizá tarde, pero bueno, me acordaré de ti ;)
Gracias!
ZEsarUX
josepzin
Mensajepor josepzin » 14 Ago 2018, 14:14
chernandezba escribió:--fullscreen juego
Me hice un .bat con esto:
D:\Juegos\Sinclair\_ZEsarUX\zesarux.exe D:\Juegos\Sinclair\ZX-Spectrum\zxspectrum\Castaway.tap --fullscreen
Y me salen una ristra de errores:
Error: Unable to open rom file 48.rom
ZEsarUX kernel panic: Unable to open rom file
PC=0000 SP=0000 BC=0000 AF=0000 HL=0000 DE=000
- F'=-------- MEMPTR=0000 IM0 IFF-- VPS: 0
Desde el menú la carga funciona bien, asi que obviamente algo estoy haciendo mal en esta linea de comandos.
Alucard_Saeba
Gracias dadas: 69 veces
Gracias recibidas: 78 veces
Mensajepor Alucard_Saeba » 14 Ago 2018, 14:36
Tiene pinta de que lo estás ejecutando fuera de su carpeta, y por eso no encuentra los archivos con la rom del 48kb y demás.
Incluye en el .bat:
d:
cd \Juegos\Sinclair\_ZEsarUX
Mensajepor Bubu » 15 Ago 2018, 13:42
chernandezba, ¿el emulador permite grabar la partida en formato de vídeo para poder subirla a YT?
Volver a “Emuladores”
