ZEsarUX-7.2 Beta
chernandezba
consola_favorita: NeoGeo
Gracias recibidas: 179 veces
ZEsarUX-7.2 Beta
Mensajepor chernandezba » 19 Dic 2018, 20:44
Hola!
He subido una nueva versión BETA de ZEsarUX 7.2
Puedes descargar una versión compilada para Mac o Windows desde:
https://github.com/chernandezba/zesarux/releases
Usuarios de Linux y otros sistemas, podéis compilar de código fuente.
Cambios en esta versión beta:
Version 7.2. 19 December 2018 - Neula edition
Added setting to specify configuration file
Improved menu environment:
* Added new menu window type: ZX Vision. GUI Windows can be moved, resized, scrolled, minimized, closed, and change the focus to the background
* Warning and Error window messages now show an animation
Added key to save text windows contents to a file
Added setting to send a final space after every word in the osd adventure keyboard
Added Dandanator CPC emulation
Added machine Amstrad CPC 4128
Improved ZRCP:
-commands smartload and snapshot-load are more intelligent now
-running in verbose or limit mode, or cpu-step command, can now update the display inmediately (having real video setting on)
Improved vu-meters: high volumes are shown in red
Improved sprite viewer: you can view sprites up to 512x512
Improved disassemble window:
*now you can export the disassemble to text file
*you can now see the full opcode when debugging Sinclair QL
*you can now show/hide hexadecimal dump of every opcode
Fixed visual glitches in some menus when Pentagon machine and real video: audio wave, visualmem, ay piano, wave piano, view sprites
Fixed visual glitches in some menus when interlaced enabled: audio wave, visualmem, ay piano, wave piano, view sprites
Fixed audio bug: sending a sample to the DAC by using Next registers, it wasn’t reseting the silence detection counter, so sound would probably be frozen (and repeated again, and again...)
Fixed autoload on tbblue (on normal and also fast boot mode)
Disfrutad!
Cesar
ZEsarUX
iturbez
Sistema Favorito: ZX81
Gracias dadas: 11 veces
Gracias recibidas: 8 veces
Re: ZEsarUX-7.2 Beta
Mensajepor iturbez » 20 Dic 2018, 14:35
No me canso de decirlo: Siempre es una buena noticia que tú emulador evolucione.
Gracias, César.
chernandezba
Mensajepor chernandezba » 20 Dic 2018, 15:45
iturbez escribió:No me canso de decirlo: Siempre es una buena noticia que tú emulador evolucione.
Gracias, César.
Gracias! :D
ZEsarUX
Demiurgo
Gracias dadas: 82 veces
Gracias recibidas: 222 veces
Mensajepor Demiurgo » 21 Dic 2018, 05:22
No sé si lo estaré haciendo mal, pero... ¿cómo se cambia de unidad? Una vez lo arranco puedo moverme por la estructura de directorios de la unidad donde está ubicado, pero no puedo cambiar a otra. ¿Es posible?
Otra cosilla, arrastrar un TAP, Z80 o cualquier otro fichero similar a la ventana del emulador no es aceptado para ejecutarlos, ¿verdad?
chernandezba
Mensajepor chernandezba » 21 Dic 2018, 08:18
Demiurgo escribió:No sé si lo estaré haciendo mal, pero... ¿cómo se cambia de unidad? Una vez lo arranco puedo moverme por la estructura de directorios de la unidad donde está ubicado, pero no puedo cambiar a otra. ¿Es posible?
Gracias por usar ZEsarUX! :D
Entiendo que usas Windows...
Para cambiar de unidad, en el selector de archivos, usa la tecla TAB para conmutar entre seleccion archivos->fitro->entrada de texto
Ahí escribes D: o lo que sea, y le das a Enter. Ten en cuenta que el teclado funciona como el Spectrum, o sea, para escribir el ":" debes pulsar ctrl o alt + z
En cuanto a arrastrar, sólo funciona por defecto en Mac (si recompilas con SDL2 también te funcionaria en cualquier sistema). El menu de Smartload permite cargar cualquier cosa que el emulador reconozca (tap, z80, zsf, zx, scr, trd, sna, wav, etc....)
ZEsarUX
Demiurgo
Mensajepor Demiurgo » 21 Dic 2018, 14:16
Gracias por la respuesta. Me ha servido. \:D/
Volver a “Emuladores”
