ZEsarUX estable 7.2
chernandezba
consola_favorita: NeoGeo
Gracias recibidas: 179 veces
ZEsarUX estable 7.2
Mensajepor chernandezba » 10 Abr 2019, 21:04
Hola!
He subido una nueva versión estable de ZEsarUX, la 7.2!
Para descargarla, como siempre, id a la parte de descargas del proyecto en GitHub:
https://github.com/chernandezba/zesarux/releases
Hay versiones binarias compiladas para:
-Linux
-Mac
-Windows
-Raspberry Pi
Y por supuesto también el código fuente para aquellos que se lo quieran compilar por ellos mismos:
No olvidéis tampoco el paquete de extras, con montones de juegos, demos, programas y documentación.
Los cambios son:
Version 7.2. 10 April 2019 - Neula edition
Improved menu environment:
-Added new menu window type: ZX Vision. GUI Windows can be moved, resized, scrolled, minimized, closed, and change the focus to the background
-Windows can be scrolled using mouse wheel
-Warning and Error window messages now show an animation
-Added first-aid help windows
Added Z80 assembler
Added setting to specify configuration file
Added key to save text windows contents to a file
Added setting to send a final space after every word in the osd adventure keyboard
Added Dandanator CPC emulation
Added machine Amstrad CPC 4128
Added CPC machines support to ZSF snapshots
Added tape to wav converter (tap, tzx, o, p to wav)
Added text driver (curses, stdout, simpletext) for Chloe 80x24 mode
Improved Debugger:
-Now you can disassemble on the Step-to-step mode from the Debug cpu menu
-Now you can assemble from the Debug cpu menu
-Added Chloe memory Zone
Improved ZRCP:
-commands smartload and snapshot-load are more intelligent now
-running in verbose or limit mode, or cpu-step command, can now update the display inmediately (having real video setting on)
-added commands: assemble, get-cpu-frequency, get-cpu-turbo-speed, get-tstates, get-tstates-partial, load-binary, reset-tstates-partial
Improved sprite viewer:
-you can view sprites up to 512x512
-you can export sprites to C source code file
Improved file selector:
-now it remembers the last files used
-Windows: now you can use up to 20000 files in the same directory
-added drive selector (press shift-d). On Windows, allows you to change drive unit. On Linux and Mac, changes to /media or /Volumes folder
Improved disassemble window:
-now you can export the disassemble to text file
-you can now see the full opcode when debugging Sinclair QL
-you can now show/hide hexadecimal dump of every opcode
Improved hexadecimal editor:
-now showing subzones information
Improved audio: silence detector is disabled by default. That should fix some Windows audio problems. Check Settings->Audio->Silence detector if you have configuration autosaving enabled
Improved vu-meters: high volumes are shown in red
Improved MMC emulation: allow non-standard mmc file sizes
Improved compiled Mac version: default version is faster than before (uses O2 optimization)
Fixed visual glitches in some menus when Pentagon machine and real video, or when enabling interlaced: audio wave, visualmem, ay piano, wave piano, view sprites
Fixed triggering "opcode" condition breakpoint
Fixed emulating Inves interrupt bug
Fixed segmentation fault when showing electron on debug
Changes in TBBlue emulation:
-Added Tiles video mode
-Added "reveal" setting to view which pixels are used by a layer
-Added setting to change machine id
-Improved CPU usage:
--Use 4% less cpu time (in my machine) when only ULA and/or Tiles enabled
--Use 1% less cpu time (in my machine) when all layers enabled
-Improved display emulation: now is twice bigger
-Fixed Timex hi-res mode 512x192
-Fixed autoload on tbblue (on normal and also fast boot mode)
-Fixed error managing Layer 2 vertical scroll
-Fixed audio bug: sending a sample to the DAC by using Next registers, it wasn't reseting the silence detection counter, so sound would probably be frozen (and repeated again, and again...)
Some other minor bugfixes and improvements
Disfrutad!
Saludos,
Cesar
ZEsarUX
cpcbegin
Gracias dadas: 183 veces
Gracias recibidas: 140 veces
Re: ZEsarUX estable 7.2
Mensajepor cpcbegin » 10 Abr 2019, 21:51
Enhorabuena y veo que viene cargadito de novedades para el CPC.
chernandezba
Mensajepor chernandezba » 11 Abr 2019, 10:13
cpcbegin escribió:Enhorabuena y veo que viene cargadito de novedades para el CPC.
Gracias. Bueno hay alguna cosilla de cpc pero tampoco mucho ;)
ZEsarUX
Volver a “Emuladores”
